ONTAP EMS reference
repl.cloud events
repl.cloud EMS events occur when ONTAP encounters issues associated with inconsistent blocks in the cloud.
repl.cloud.incons.buf
Severity
ERROR
This message occurs when the replication engine encounters an inconsistent block in the cloud.
Corrective Action
Contact NetApp technical support.
Syslog Message
REPL cloud inconsistent: bad block in %s inode (fileid:%s rootcbn:%u) at fbn:%llu level:%u in volume %llu. Abort when corruption is encountered:%u.
file_space (STRING): File space.
fileid (STRING): Identifying number for the suspect inode.
rootcbn (LONGINT): Snapshot inofile root.
fbn (LONGINT): File block number.
level (INT): Buffer level.
dsid (LONGINT): Dsid of the volume.
abort (INT): Abort when corrupt block is encountered.
repl.cloud.incons.gc
Severity
ERROR
This message occurs when the replication engine encounters inconsistent map object in the cloud. This does not cause user data corruption but can result in few dangling objects.
Corrective Action
Syslog Message
REPL cloud inconsistent: Corrupted cloud data detected in cloud snapshot:%s, cloud snapshot UUID:%s, cloud object:%s.
snapshot_name (STRING): Cloud snapshot name.
snapshot_uuid (STRING): Cloud snapshot Universally Unique ID (UUID).
object_name (STRING): Cloud object name.
