repl.cloud events
repl.cloud EMS events occur when ONTAP encounters issues associated with inconsistent blocks in the cloud.
repl.cloud.incons.buf
- Severity
ERROR
- Description
This message occurs when the replication engine encounters an inconsistent block in the cloud.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
REPL cloud inconsistent: bad block in %s inode (fileid:%s rootcbn:%u) at fbn:%llu level:%u in volume %llu. Abort when corruption is encountered:%u.
- Parameters
file_space (STRING): File space.
fileid (STRING): Identifying number for the suspect inode.
rootcbn (LONGINT): Snapshot inofile root.
fbn (LONGINT): File block number.
level (INT): Buffer level.
dsid (LONGINT): Dsid of the volume.
abort (INT): Abort when corrupt block is encountered.
repl.cloud.incons.gc
- Severity
ERROR
- Description
This message occurs when the replication engine encounters inconsistent map object in the cloud. This does not cause user data corruption but can result in few dangling objects.
- Corrective Action
- Syslog Message
REPL cloud inconsistent: Corrupted cloud data detected in cloud snapshot:%s, cloud snapshot UUID:%s, cloud object:%s.
- Parameters
snapshot_name (STRING): Cloud snapshot name.
snapshot_uuid (STRING): Cloud snapshot Universally Unique ID (UUID).
object_name (STRING): Cloud object name.
