ONTAP EMS reference
scsiblade.mapped events
scsiblade.mapped.ns.attr.mod
Severity
ERROR
This message occurs when a mapped NVMe namespace attribute changes as a result of a management operation. Changes in NVMe namespace attributes like size, state, or OS type, are not supported in this release.
Corrective Action
Remove the namespace map using "vserver nvme subsystem map remove" command, then reapply it with the "vserver nvme subsystem map add" command.
Syslog Message
The Namespace attributes of the Namespace with Vdisk ID '%s' in volume with MSID '%llu' in Vserver '%s' changed.
vdiskId (STRING): Vdisk ID of the LUN.
volume (LONGINTHEX): Volume identifier.
vserver (STRING): UUID of the Vserver that hosts the LUN.
