ONTAP EMS reference
secd.rpc events
secd.rpc.authRequest.blocked
Severity
ALERT
This message occurs when a user with the same domain and same client IP address is blocked due to continuous authentication requests with an invalid login password.
Corrective Action
Check if there is an unexpected increase in the number of authentication requests with an invalid login password from a particular CIFS client. Use "statistics show -raw -object secd -instance secd -counter num_rpcs_blocked_due_to_wrong_password" command to check the number of clients blocked due to an invalid password.
Syslog Message
Too many CIFS authentication attempts with an invalid password from a client with IP "%s", user name "%s" and domain "%s" on SVM "%s".
clientIP (STRING): IP address of the client that has been blocked.
userName (STRING): User who is trying to mount with an invalid password.
domain (STRING): Domain to which the user belongs.
vserverName (STRING): Storage virtual machine(SVM) associated with this operation.
secd.rpc.server.ready
Severity
INFORMATIONAL
This message occurs when SecD successfully loads the configuration and is ready to serve all RPCs.
Corrective Action
(None).
Syslog Message
SecD is ready to serve all RPCs.
(None).
secd.rpc.server.request.dropped
Severity
ERROR
This message occurs when a remote procedure call(RPC) is dropped by SecD due to a lack of memory space. It might occur either when SecD receives too many requests than it can handle or when a number of requests have accumulated due to server connectivity issues.
Corrective Action
Check whether there is an unexpected increase in the number of authentication requests from NFS/CIFS clients. Verify that there are no connectivity issues to the external servers like DNS, LDAP, and DC.
Syslog Message
RPC "%s" that was sent from "%s" was dropped by SecD due to a lack of memory space.
rpcName (STRING): Name of the RPC that has been dropped.
callerName (STRING): Caller of the RPC that has been dropped.
