      sfu.partnerupdatetimeout events
sfu.partnerUpdateTimeout
- Severity
INFORMATIONAL
 - Description
This message occurs in a high-availability (HA) configuration in which an HA partner was downloading disk shelf firmware and the download has timed out. The system resumes enclosure services monitoring.
 - Corrective Action
Verify that the HA interconnect is operational and then retry the (advanced privilege) "storage shelf firmware update" command.
 - Syslog Message
Waited %d minutes for partner shelf firmware update. Resuming enclosure services.
 - Parameters
minutes (INT): Duration of the partner update timeout, in minutes.
