ONTAP EMS reference
sfu.suspendses events
sfu.suspendSES
Severity
INFORMATIONAL
This message occurs when a disk shelf firmware update is requested in a high-availability (HA) environment. One partner node updates the firmware on the disk shelf module while the HA partner node temporarily disables enclosure services while the firmware update is in process.
Corrective Action
(None).
Syslog Message
Suspending enclosure services—​partner is updating disk shelf firmware.
(None).
