ONTAP EMS reference
sp.wdog events
sp.wdog.set.fail
Severity
ERROR
This message occurs when ONTAP® software fails to disable or enable the service-processor' (SP or BMC) watchdog timer. This might occur due to an intermittent SP or BMC firmware failure.
Corrective Action
If the system continues to run normally, you can ignore this message. If a system disruption occurs after this failure, reboot the SP or BMC or power-cycle the system before starting ONTAP or performing a giveback. If system disruptions continue to occur, contact NetApp technical support for assistance.
Syslog Message
Unable to %s service-processor's watchdog timer. Error code: 0x%x.
op (STRING): Whether the failure was to enable or disable the timer.
errcode (INT): Error code for debugging.
