tapemc.unsupported events
tapemc.unsupported EMS events occur when a tape or media changer is detected that is not supported on this system, but its usage is not blocked.
tapemc.unsupported.allow
- Severity
ERROR
- Description
This message occurs when a tape or media changer is detected that is not supported on this system, but its usage is not blocked. Use at your own risk.
- Corrective Action
Remove the tape or media changer device, or use at your own risk.
- Syslog Message
Attaching a tape or media changer device on adapter %s is not supported on this system.
- Parameters
AdapterName (STRING): Adapter name to which the tape device is attached.
