tar.csum events
tar.csum EMS events occur when ONTAP encounters issues associated with TAR archive checksum operations.
tar.csum.csumUnsuccessful
- Severity
NOTICE
- Description
This message occurs when the system accesses a TAR archive and compares the calculated checksum of this archive to a stored checksum, but the checksum calculation does not succeed.
- Corrective Action
(None).
- Syslog Message
Checksum of %s could not be calculated.
- Parameters
tgz_path (STRING): Path to the archive for which the checksum calculation failed.
tar.csum.extractFailed
- Severity
ERROR
- Description
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum, but the extraction of such an archive fails.
- Corrective Action
(None).
- Syslog Message
TAR extraction of %s failed with rc=%d.
- Parameters
tgz_path (STRING): Path to the archive for which extraction failed.
rc (INT): Error code clarifying why the extraction of the archive failed.
tar.csum.match
- Severity
INFORMATIONAL
- Description
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the calculated and stored checksums for the archive match.
- Corrective Action
(None).
- Syslog Message
Stored checksum matches, not extracting %s.
- Parameters
tgz_path (STRING): Path to the archive for which the calculated and stored checksums match.
tar.csum.mismatch
- Severity
NOTICE
- Description
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the calculated and stored checksums for the TAR archive do not match.
- Corrective Action
(None).
- Syslog Message
Stored checksum %u does not match calculated checksum %u, extracting %s.
- Parameters
stored_csum (INTHEX): Value of the stored checksum.
calculated_csum (INTHEX): Value of the calculated checksum.
tgz_path (STRING): Path to the archive for which the calculated and stored checksums do not match.
tar.csum.notFound
- Severity
NOTICE
- Description
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the file containing the stored checksum does not exist, necessitating the extraction of the archive.
- Corrective Action
(None).
- Syslog Message
Stored checksum file does not exist, extracting %s.
- Parameters
tgz_path (STRING): Path to the archive for which a corresponding stored checksum file does not exist.
