ONTAP EMS reference
tar.csum events
tar.csum EMS events occur when ONTAP encounters issues associated with TAR archive checksum operations.
tar.csum.csumUnsuccessful
Severity
NOTICE
This message occurs when the system accesses a TAR archive and compares the calculated checksum of this archive to a stored checksum, but the checksum calculation does not succeed.
Corrective Action
(None).
Syslog Message
Checksum of %s could not be calculated.
tgz_path (STRING): Path to the archive for which the checksum calculation failed.
tar.csum.extractFailed
Severity
ERROR
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum, but the extraction of such an archive fails.
Corrective Action
(None).
Syslog Message
TAR extraction of %s failed with rc=%d.
tgz_path (STRING): Path to the archive for which extraction failed.
rc (INT): Error code clarifying why the extraction of the archive failed.
tar.csum.match
Severity
INFORMATIONAL
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the calculated and stored checksums for the archive match.
Corrective Action
(None).
Syslog Message
Stored checksum matches, not extracting %s.
tgz_path (STRING): Path to the archive for which the calculated and stored checksums match.
tar.csum.mismatch
Severity
NOTICE
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the calculated and stored checksums for the TAR archive do not match.
Corrective Action
(None).
Syslog Message
Stored checksum %u does not match calculated checksum %u, extracting %s.
stored_csum (INTHEX): Value of the stored checksum.
calculated_csum (INTHEX): Value of the calculated checksum.
tgz_path (STRING): Path to the archive for which the calculated and stored checksums do not match.
tar.csum.notFound
Severity
NOTICE
This message occurs when the system accesses a TAR archive and compares the calculated checksum of the archive to a stored checksum. In this case, the file containing the stored checksum does not exist, necessitating the extraction of the archive.
Corrective Action
(None).
Syslog Message
Stored checksum file does not exist, extracting %s.
tgz_path (STRING): Path to the archive for which a corresponding stored checksum file does not exist.
