ONTAP EMS reference
volume.transition events
volume.transition.plugin.slow
Severity
INFORMATIONAL
This message occurs when a volume transition plug-in is taking longer than expected.
Corrective Action
(None).
Syslog Message
Volume transition on volume %s, plug-in %s running %d ms (expected %d ms).
voluuid (STRING): Unique identifier for this volume.
plugin (STRING): Name of the slow plug-in.
used (INT): Runtime for the plug-in, in milliseconds.
expected (INT): Expected runtime for the plug-in, in milliseconds.
