volume.transition events
volume.transition EMS events occur when a volume transition plug-in is taking longer than expected.
volume.transition.plugin.slow
- Severity
INFORMATIONAL
- Description
This message occurs when a volume transition plug-in is taking longer than expected.
- Corrective Action
(None).
- Syslog Message
Volume transition on volume %s, plug-in %s running %d ms (expected %d ms).
- Parameters
voluuid (STRING): Unique identifier for this volume.
plugin (STRING): Name of the slow plug-in.
used (INT): Runtime for the plug-in, in milliseconds.
expected (INT): Expected runtime for the plug-in, in milliseconds.
