ONTAP EMS reference
wafl.descend events
wafl.descend.fail
Severity
ERROR
This message occurs when there is an error during descendency checking. This message can occur when accessing a directory in a snapshot that is being deleted.
Corrective Action
This condition might be transient; try the operation again. If the problem persists, contact NetApp technical support.
Syslog Message
Descendency check failure: {x%x %d %d %d %d} parent of {x%x %d %d %d %d}. Contact NetApp technical support.
pfh0 (INT): Parent file handle's flags.
pfh1 (INT): Parent file handle's snapid.
pfh2 (INT): Parent file handle's fileid.
pfh3 (INT): Parent file handle's generation.
pfh4 (INT): Parent file handle's FSID.
cfh0 (INT): Child file handle's flags.
cfh1 (INT): Child file handle's snapid.
cfh2 (INT): Child file handle's fileid.
cfh3 (INT): Child file handle's generation.
cfh4 (INT): Child file handle's FSID.
vendor (STRING): Vendor contact information.
