ONTAP EMS reference
xfcvi.link events
xfcvi.link EMS events occur when ONTAP encounters issues associated with the Fibre Channel Virtual Interface (FC-VI) adapter physical link.
Severity
NOTICE
This message occurs when the physical link of the Fibre Channel Virtual Interface (FC-VI) adapter goes down.
Corrective Action
  1. Ensure that the FC-VI link has not been tampered with. 2. Verify that the physical status of the FC-VI adapter is "Up" by using the command "metrocluster interconnect adapter show". 3. If the configuration includes fabric switches, ensure that they are properly cabled and configured.
Syslog Message
(None).
alertId (STRING): Alert ID.
alertingResource (STRING): Alerting resource unique name.
alertingResourceName (STRING): Alerting resource name.
possibleEffect (STRING): Possible effect for link transition.
probableCause (STRING): Probable cause of the event.
probableCauseDescription (STRING): Probable cause description of the event.
additionalInfo (STRING): Any additional information for the event.
Severity
NOTICE
This message occurs when the physical link of the Fibre Channel Virtual Interface (FC-VI) adapter comes up.
Corrective Action
(None).
Syslog Message
(None).
