availability.zone events
availability.zone EMS events occur when ONTAP encounters issues associated with storage availability zone space usage exceeding threshold values.
availability.zone.full
- Severity
ALERT
- Description
This message occurs when the storage availability zone space usage has exceeded the full threshold value. If physical space usage surpasses 100%, the storage availability zone will be overallocated.
- Corrective Action
Create space by increasing the storage availability zone size, by deleting data or by deleting Snapshot copies.
- Syslog Message
Physical space used (%s%%) by storage availability zone (%s) exceeds the full threshold (%d%%).
- Parameters
percent_full (STRING): Physical used space of the storage availability zone, as a percent.
pod_uuid (STRING): UUID of the storage availability zone.
percent_threshold (INT): Threshold percentage of physical used space which triggers the storage full condition.
availability.zone.nearlyFull
- Severity
ERROR
- Description
This message occurs when the storage availability zone space usage has exceed the nearly full threshold value.
- Corrective Action
- Syslog Message
Physical space used (%s%%) by storage availability zone (%s) exceeds the nearly full threshold (%d%%).
- Parameters
percent_threshold (INT): Threshold percentage of physical used space which triggers the storage nearly full condition.
availability.zone.ok
- Severity
NOTICE
- Description
This message occurs when the storage availability zone space usage level is below the nearly full threshold value.
- Corrective Action
(None).
- Syslog Message
Physical space used (%s%%) by storage availability zone (%s) is below nearly full threshold (%d%%).
- Parameters
availability.zone.overalloc
- Severity
EMERGENCY
- Description
This message occurs when the storage availability zone space usage has exceeded the storage availability zone size. Once the physical use is beyond 100%, it may cause the availability zone to be taken offline.
- Corrective Action
- Syslog Message
Physical space used (%s%%) by the storage availability zone (%s) exceeds maximum space in the storage availability zone.
- Parameters
