ONTAP EMS reference
availability.zone events
availability.zone EMS events occur when ONTAP encounters issues associated with storage availability zone space usage exceeding threshold values.
availability.zone.full
Severity
ALERT
This message occurs when the storage availability zone space usage has exceeded the full threshold value. If physical space usage surpasses 100%, the storage availability zone will be overallocated.
Corrective Action
Create space by increasing the storage availability zone size, by deleting data or by deleting Snapshot copies.
Syslog Message
Physical space used (%s%%) by storage availability zone (%s) exceeds the full threshold (%d%%).
percent_full (STRING): Physical used space of the storage availability zone, as a percent.
pod_uuid (STRING): UUID of the storage availability zone.
percent_threshold (INT): Threshold percentage of physical used space which triggers the storage full condition.
availability.zone.nearlyFull
Severity
ERROR
This message occurs when the storage availability zone space usage has exceed the nearly full threshold value.
Corrective Action
Syslog Message
Physical space used (%s%%) by storage availability zone (%s) exceeds the nearly full threshold (%d%%).
percent_threshold (INT): Threshold percentage of physical used space which triggers the storage nearly full condition.
availability.zone.ok
Severity
NOTICE
This message occurs when the storage availability zone space usage level is below the nearly full threshold value.
Corrective Action
(None).
Syslog Message
Physical space used (%s%%) by storage availability zone (%s) is below nearly full threshold (%d%%).
availability.zone.overalloc
Severity
EMERGENCY
This message occurs when the storage availability zone space usage has exceeded the storage availability zone size. Once the physical use is beyond 100%, it may cause the availability zone to be taken offline.
Corrective Action
Syslog Message
Physical space used (%s%%) by the storage availability zone (%s) exceeds maximum space in the storage availability zone.
