cifs.db events
cifs.db EMS events occur when a CIFS server fails to be removed on the secondary site for an SVM in a MetroCluster configuration or SVM DR setup.
cifs.db.v2.exists
- Severity
ERROR
- Description
This message occurs when a CIFS server fails to be removed on the secondary site for an SVM in a MetroCluster configuration or SVM DR setup. The stale CIF server might cause issues when it is reprovisioned.
- Corrective Action
If this is a SnapMirror or MetroCluster environment, run the "snapmirror resync" command or the "metrocluster vserver resync" command respectively to resynchronize the Vserver configuration.
- Syslog Message
Stale CIFS server exists and may cause issues when reprovisioned. Vserver: %s Cifs Server: %s Error: %s.
- Parameters
reason (STRING): Reason for the failure.
Vservername (STRING): Name of the Vserver.
cifsservername (STRING): Name of the cifs server.
