ONTAP EMS reference
cifs.db events
cifs.db EMS events occur when a CIFS server fails to be removed on the secondary site for an SVM in a MetroCluster configuration or SVM DR setup.
cifs.db.v2.exists
Severity
ERROR
This message occurs when a CIFS server fails to be removed on the secondary site for an SVM in a MetroCluster configuration or SVM DR setup. The stale CIF server might cause issues when it is reprovisioned.
Corrective Action
If this is a SnapMirror or MetroCluster environment, run the "snapmirror resync" command or the "metrocluster vserver resync" command respectively to resynchronize the Vserver configuration.
Syslog Message
Stale CIFS server exists and may cause issues when reprovisioned. Vserver: %s Cifs Server: %s Error: %s.
reason (STRING): Reason for the failure.
Vservername (STRING): Name of the Vserver.
cifsservername (STRING): Name of the cifs server.
