ONTAP EMS reference
ctl.session events
ctl.session EMS events occur when iSCSI CAM target layer session status is changed.
ctl.session.stateChanged
Severity
NOTICE
This message occurs when iSCSI CAM target layer session status is changed.
Corrective Action
If the identified iSCSI CAM target layer session is experiencing unexpected events (disconnecting, reconnecting, or connected), examine the link for excessive errors or latency.
Syslog Message
iSCSI CAM target layer's session state is changed to %s for the initiator %s (address: %s). %s
ctl_session_state (STRING): New iSCSI CAM target layer session state.
ctl_initiator (STRING): iSCSI CAM target layer initiator's name.
ctl_initiator_address (STRING): iSCSI CAM target layer initiator's address.
ctl_session_state_change_reason (STRING): Reason for the iSCSI CAM target layer session state change.
ctl_timeout_value (INT): iSCSI CAM target layer timeout value.
