ONTAP EMS reference
ipmultipath.init events
ipmultipath.init EMS events occur when ONTAP encounters issues associated with IP Multipath session initialization.
ipmultipath.init.badChksumType
Severity
ERROR
This message occurs during IP Multipath session initialization, when an INIT packet with an unknown checksum type is received.
Corrective Action
The two end points are possibly running incompatible versions of ONTAP. Run identical/compatible versions of ONTAP on the two end points and try again.
Syslog Message
Unknown checksum type (%d) in IP Multipath INIT packet.
chksum_type (INT): Checksum type received.
ipmultipath.init.badVersion
Severity
ERROR
This message occurs during IP Multipath session initialization, when an INIT packet with an unknown version number is received.
Corrective Action
Syslog Message
Unknown version (%d) in IP Multipath INIT packet.
version (INT): Version number received.
