km.kmip events
km.kmip EMS events occur when ONTAP encounters issues associated with external key manager NSE-AK keys in MetroCluster configurations.
km.kmip.key.mismatch
- Severity
ALERT
- Description
This message occurs in a NetApp MetroCluster configuration where both peer clusters are configured with the external key manager on the admin Vserver, but the NSE-AK keys do not match between the local and remote clusters. A mismatch in the NSE-AK keys can cause a failure during a reboot or future switchover/switchback event.
- Corrective Action
Contact Contact NetApp technical support. for assistance.
- Syslog Message
In a MetroCluster configuration with the external key manager enabled on the admin Vserver, the NSE-AK key digests do not match between the local and remote clusters.
- Parameters
(None).
km.kmip.key.missing
- Severity
ALERT
- Description
This message occurs in a NetApp MetroCluster configuration where both peer clusters are configured with the external key manager on the admin Vserver, but one or more NSE-AK keys are missing on either the local or remote cluster. A missing key can cause a failure during a reboot or future switchover/switchback event.
- Corrective Action
- Syslog Message
In a MetroCluster configuration with the external key manager enabled on the admin Vserver, an NSE-AK key is missing on cluster %s.
- Parameters
clusterID (STRING): Cluster ID where the NSE-AK key is missing.
