ONTAP EMS reference
monitor.chassispowersupply events
monitor.chassispowersupply EMS events occur when ONTAP encounters issues associated with chassis power supply status.
monitor.chassisPowerSupply.degraded
Severity
NOTICE
This message occurs when a power supply is degraded.
Corrective Action
A replacement power supply might be required. Contact NetApp technical support for further direction.
Syslog Message
Chassis power supply %d is degraded: %s
ps_number (INT): Power supply number.
reasonText (STRING): Description of the degradation.
monitor.chassisPowerSupply.notPresent
Severity
NOTICE
This message occurs when an expected a power supply is not present.
Corrective Action
Add a power supply to the controller chassis.
Syslog Message
Chassis power supply %d is not present.
monitor.chassisPowerSupply.off
Severity
NOTICE
This message occurs when a power supply is off.
Corrective Action
Turn on the power supply.
Syslog Message
Chassis power supply %d off.
monitor.chassisPowerSupply.ok
Severity
INFORMATIONAL
This message occurs when the power supply is OK.
Corrective Action
(None).
Syslog Message
Chassis power supply %d is OK.
