ONTAP EMS reference
net.asymmetric events
net.asymmetric EMS events occur when ONTAP® detects asymmetric routing on the e0M port.
net.asymmetric.routing.e0m
Severity
NOTICE
This message occurs when ONTAP® detects asymmetric routing on the e0M port. Sending non-management traffic over the e0M port is unsupported and will cause performance degradation.
Corrective Action
Use the "network route show" command to check the routes configured on the system storage virtual machine (SVM). Use the "network route create" command to add missing routes with a gateway in the subnet of the LIFs that are not hosted on the e0M port.
Syslog Message
Traffic destined for %s from source LIF %s, which is not hosted on e0M, is being routed through e0M.
Dst (STRING): IP address of the destination.
Src (STRING): IP address of the source.
