ONTAP EMS reference
netif.ena events
netif.ena EMS events occur when ONTAP encounters issues associated with AWS Elastic Network Adapter (ENA) operations.
netif.ena.express.changed
Severity
NOTICE
This message occurs when AWS ENA Express feature is changed for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is changed from mode "%s" to "%s".
ifName (STRING): Name of the network interface.
oldMode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
newMode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
netif.ena.express.detected
Severity
NOTICE
This message occurs when AWS ENA Express feature is turned on for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is detected: mode "%s".
mode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
netif.ena.express.disabled
Severity
NOTICE
This message occurs when AWS ENA Express feature is disabled for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is disabled from mode "%s".
