ONTAP EMS reference
netif.ena events
netif.ena EMS events occur when ONTAP encounters issues associated with AWS Elastic Network Adapter (ENA) operations.
netif.ena.allowance.exceeded
Severity
NOTICE
This message occurs when the network throughput exceeds the bandwidth allowance for the node
Corrective Action
(None).
Syslog Message
"%s" AWS ENA metric "%s" changed from %llu to %llu.
ifName (STRING): Name of the network interface
metric (STRING): Only one of the following metrics is displayed at a time. bw_in_allowance_exceeded: The number of packets queued or dropped because the inbound aggregate bandwidth exceeded the maximum for the instance. bw_out_allowance_exceeded: The number of packets queued or dropped because the outbound aggregate bandwidth exceeded the maximum for the instance. pps_allowance_exceeded: The number of packets queued or dropped because the bidirectional Packet-per-second exceeded the maximum for the instance.
oldValue (LONGINT): old ena metric value
newValue (LONGINT): new ena metric value
netif.ena.express.changed
Severity
NOTICE
This message occurs when AWS ENA Express feature is changed for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is changed from mode "%s" to "%s".
ifName (STRING): Name of the network interface.
oldMode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
newMode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
netif.ena.express.detected
Severity
NOTICE
This message occurs when AWS ENA Express feature is turned on for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is detected: mode "%s".
mode (STRING): ENA Express feature bits (0: off, 1: on with TCP, 2: on with UDP)
netif.ena.express.disabled
Severity
NOTICE
This message occurs when AWS ENA Express feature is disabled for the NIC.
Corrective Action
(None).
Syslog Message
AWS ENA Express for "%s" is disabled from mode "%s".
