nvme.fw events
nvme.fw EMS events occur when ONTAP encounters issues associated with NVMe drive firmware activation.
nvme.fw.activate.complete
- Severity
NOTICE
- Description
This message occurs when new firmware has been successfully activated on the drive and running normally.
- Corrective Action
(None).
- Syslog Message
NVMe caching module in physical slot %s with serial number %s, and model number %s successfully replaced firmware version %s with %s in firmware slot %u.
- Parameters
slot_subslot (STRING): PCI slot of the NVMe device.
serial (STRING): Serial number of the controller.
model (STRING): Model number of the controller.
old (STRING): Version of firmware that has been replaced.
new (STRING): Version of firmware that was activated.
fw_slot (INT): Firmware slot that the new version was programmed to.
reset (INT): An indication on whether the device had to be reset or not in order to activate the firmware.
nvme.fw.activate.failed
- Severity
ERROR
- Description
This message occurs when there was an issue while activating the new firmware on the the NVMe drive. The caching module will continue normal operation with obsolete firmware.
- Corrective Action
The caching module is still completely functional, but it is running with obsolete firmware. Contact NetApp technical support for alternative solutions.
- Syslog Message
NVMe caching module in slot %s with serial number %s and model number %s failed to activate firmware. Error code: 0x%llx.
- Parameters
code (LONGINTHEX): Internal error code.
nvme.fw.program.failed
- Severity
ERROR
- Description
This message occurs when there was an issue while downloading new firmware to the NVMe drive. The caching module will continue normal operation with obsolete firmware.
- Corrective Action
The caching module is still completely functional however it is running with obsolete firmware. Contact NetApp technical support for alternative solutions.
- Syslog Message
NVMe caching module in slot %s with serial number %s, and model number %s failed to download firmware version %s to the drive with error code 0x%llx.
- Parameters
version (STRING): Version of firmware attempted to download.
