ONTAP EMS reference
nvmeof.mixedports events
nvmeof.mixedports EMS events occur when ONTAP encounters issues associated with mixed dedicated and nondedicated port connections to shelves.
nvmeof.mixedports.clear
Severity
NOTICE
This message occurs when there is no longer a nonrecommended mix of a dedicated port and a nondedicated port cabled from a node to a shelf.
Corrective Action
(None).
Syslog Message
There is no longer a nonrecommended mix of a dedicated port and a nondedicated port cabled from node %s to shelf with SN %s.
node_name (STRING): Host port connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.mixedports.error
Severity
ERROR
This message occurs when both primary and secondary host ports are incorrectly cabled to a shelf. This cabling might compromise physical data link redundancy and inhibit system performance.
Corrective Action
Connect either primary dedicated ports or secondary nondedicated ports to the shelf, but not both port types.
Syslog Message
There is a nonrecommended mix of a dedicated port and a nondedicated port cabled from node %s to Shelf with SN %s.
