ONTAP EMS reference
sfu.adaptersuspendio events
sfu.adaptersuspendio EMS events occur when ONTAP encounters issues associated with disk shelf firmware update I/O suspension.
sfu.adapterSuspendIO
Severity
INFORMATIONAL
This message occurs during a disk shelf firmware update on a disk shelf that cannot perform I/O while updating firmware. Typically, the shelves involved are bridge-based.
Corrective Action
I/O resumes automatically after the firmware update is complete.
Syslog Message
Suspending I/O to %s adapter %s for %d seconds while shelf firmware is updated.
adapterType (STRING): Type of adapter that is updating firmware.
channelName (STRING): Name of the adapter on which shelves will be updating firmware.
minutes (INT): Amount of time that I/O will be suspended on the adapter.
sfu.adapterSuspendIO.ndu
Severity
INFORMATIONAL
This message occurs during a disk shelf firmware update on a disk shelf that can perform I/O, but might have to suspend management requests while updating firmware. Typically, the shelves involved are DS12-ESAS, DS20-ESAS, DS4243.
Corrective Action
Suspended data traffic resumes automatically after the firmware update is complete.
Syslog Message
Suspending %s to %s adapter %s for %d seconds while shelf firmware is updated.
dataTrafficType (STRING): Type of data traffic: SMP.
minutes (INT): Amount of time that specified data traffic will be suspended on the adapter.
