ONTAP EMS reference
vserver.storage events
vserver.storage EMS events occur when ONTAP encounters issues associated with Vserver storage capacity limits.
vserver.storage.full
Severity
ERROR
This message occurs when the Storage of Vserver is full.
Corrective Action
Increase the available size of Vserver either by raising storage-limit or by downsizing or deleting volumes.
Syslog Message
Vserver "%s" is full by consuming the storage limit "%s".
vserver_name (STRING): Vserver name for which the storage is full.
storage_limit (STRING): The storage-limit for the Vserver.
vserver.storage.nearlyFull
Severity
ALERT
This message occurs when the Vserver storage size exceeds 95% of the storage limit.
Corrective Action
Syslog Message
Vserver "%s" with current storage size of "%s" has exceeded "95%%" of storage limit "%s".
vserver_name (STRING): Vserver name for which the storage size has exceeded 95% of the storage limit.
storage_size (STRING): The storage used size of the Vserver.
vserver.storage.size.breached
Severity
NOTICE
This message occurs when tenant has exceeded the capacity quota allotted to the Vserver. The checker automatically deselects this mismatch and attempts a fix. To see details including the updated size use "vserver show -fields storage-limit,storage-allocated,storage-reserved" command.
Corrective Action
(None).
Syslog Message
Vserver "%s" size "%s" has exceeded storage capacity quota of "%s".
vserver_name (STRING): The Vserver whose size exceeded the capacity quota alloted to the tenant.
vserver_size (STRING): Vserver's size allotted up to a point to the tenant.
capacity_limit (STRING): Capacity limit allotted to the Vserver.
vserver.storage.size.mismatch
Severity
NOTICE
This message occurs when the Vserver's size allotted to the tenant up to a point does not match sum of all the volume's provisioned size that can be used to enforce Vserver capacity quota. The checker automatically deselects this mismatch and attempts a fix. To see details including the updated size use "vserver show -fields storage-limit,storage-allocated,storage-reserved" command.
Corrective Action
(None).
Syslog Message
Vserver "%s" size allocated to the tenant up to a point "%s" does not match sum of all the volume's provisioned size "%s".
vserver_name (STRING): Vserver for which the size allotted to the tenant up to a point does not match sum of all the volume's provisioned size.
provisioned_size (STRING): Sum of all the volume's provisioned size in Vserver.
vserver.storage.threshold
Severity
ALERT
This message occurs when the Vserver storage size exceeds the storage-limit-threshold-alert value.
Corrective Action
Syslog Message
Vserver "%s" with current storage size of "%s" has exceeded "%s%%" of storage limit "%s".
vserver_name (STRING): Vserver name for which the storage size has exceeded the storage-limit-threshold-alert value.
storage_limit_threshold (STRING): The storage-limit-threshold-alert value of the Vserver.
