ONTAP EMS reference
wafl.gran events
wafl.gran EMS events occur when ONTAP encounters issues associated with advanced granular data support during SnapMirror transfers.
wafl.gran.data.adv.not.on
Severity
ERROR
This message occurs when a SnapMirror transfer fails because a snapshot that contains multipart inodes is transferred to a destination volume that does not support advanced granular data. Multipart inodes are created on volumes with granular data enabled.
Corrective Action
Enable granular data on the destination volume using the command <granular-data advanced>".
Syslog Message
SnapMirror transfer failed because the transfer snapshot contains multipart inodes and the destination volume, "%s", does not support advanced granular data.
volName (STRING): Volume name.
wafl.gran.data.basic.not.on
Severity
ERROR
This message occurs when a SnapMirror transfer fails because a snapshot that contains multipart inodes is transferred to a destination volume that does not support basic granular data. Multipart inodes are created on volumes with granular data enabled.
Corrective Action
Enable granular data on the destination volume using the command <granular-data basic>.
Syslog Message
SnapMirror transfer failed because the transfer snapshot contains multipart inodes and the destination volume, "%s", does not support them.
