wafl.gran events
wafl.gran EMS events occur when ONTAP encounters issues associated with advanced granular data support during SnapMirror transfers.
wafl.gran.data.adv.not.on
- Severity
ERROR
- Description
This message occurs when a SnapMirror transfer fails because a snapshot that contains multipart inodes is transferred to a destination volume that does not support advanced granular data. Multipart inodes are created on volumes with granular data enabled.
- Corrective Action
Enable granular data on the destination volume using the command <granular-data advanced>".
- Syslog Message
SnapMirror transfer failed because the transfer snapshot contains multipart inodes and the destination volume, "%s", does not support advanced granular data.
- Parameters
volName (STRING): Volume name.
wafl.gran.data.basic.not.on
- Severity
ERROR
- Description
This message occurs when a SnapMirror transfer fails because a snapshot that contains multipart inodes is transferred to a destination volume that does not support basic granular data. Multipart inodes are created on volumes with granular data enabled.
- Corrective Action
Enable granular data on the destination volume using the command <granular-data basic>.
- Syslog Message
SnapMirror transfer failed because the transfer snapshot contains multipart inodes and the destination volume, "%s", does not support them.
- Parameters
