ONTAP EMS reference
wafl.nvlog events
wafl.nvlog EMS events occur when ONTAP encounters issues associated with nvlog file operations and version compatibility.
wafl.nvlog.stats.createError
Severity
NOTICE
This event is issued to indicate that the system is unable to create nvlog stats file.
Corrective Action
(None).
Syslog Message
Can't create nvlog replay stats file
(None).
wafl.nvlog.stats.writeError
Severity
NOTICE
This event is issued to indicate the system is unable to write to nvlog stats file.
Corrective Action
(None).
Syslog Message
Nvlog replay stats fio_write failed
(None).
wafl.nvlog.versionFail
Severity
ALERT
This message occurs when the nvlog version found in the NV log is not recognized by the current version of Data ONTAP®.
Corrective Action
This might be the result of an upgrade or revert attempt after a dirty boot. If so, try the upgrade or revert after a clean shutdown. If the problem persists, or if this was not due to an upgrade or revert, contact NetApp technical support.
Syslog Message
Could not replay WAFL NV log: nvlog format is of a prior or future release (%d, %d).
version (INT): WAFL® NV log version in the NV log.
myversion (INT): Kernel WAFL NV log version.
