ONTAP EMS reference
config.badslot events
config.badslot EMS events occur when a disk is found to be attached to an invalid Host Adapter (HA) controller slot.
config.BadSlot
Severity
ALERT
This message occurs when a disk is found to be attached to an invalid Host Adapter (HA) controller slot.
Corrective Action
Consult the NetApp technical support guides for the supported slots for adapters in the hardware platform. If the adapter is in a supported slot, contact NetApp technical support for further assistance.
Syslog Message
Disk %s is attached to an invalid HA slot. This is an illegal configuration.
disk (STRING): Name of the disk.
