ONTAP EMS reference
de.job events
de.job EMS events occur when a job in AIDP fails to complete successfully.
de.job.failure
Severity
ERROR
This message occurs when a job in AIDP fails to complete successfully. An EMS event will be logged every time a job moves to failure state.
Corrective Action
Check the description of the job that has failed and retry the workflow if necessary. For example, if the workspace creation job failed, check which sub-job or task caused the failure and retry the workflow. The following API shows all details of the job - /data-engine/jobs/{uuid} where uuid is jobId param.
Syslog Message
Job failure event for AIDP with id: %s, owner: %s, description: %s, user/group: %s, severity: %s, createTime: %s, resource UUID: %s, resource name: %s, resource type: %s, job ID: %s, job name: %s, job type: %s, job state: %s
id (STRING): Event ID of the job failure event.
owner (STRING): Owner of the event.
description (STRING): Description of the job failure event.
userOrGroup (STRING): User or group that owns the job failure event.
severity (STRING): Severity of the event.
createTime (STRING): Creation time.
resourceUUID (STRING): ID of the resource - workspace, data collection, policy ID etc.
resourceName (STRING): Name of the resource.
resourceType (STRING): Resource type of the event - workspace, data collection, policy etc.
jobId (STRING): Job ID of the job that failed.
jobName (STRING): Name of the job that failed.
jobType (STRING): Job type of the job that failed.
jobState (STRING): Job state of the job that failed.
attributes (STRING): Dynamic attributes related to the job failure event. It can be anything like size, space, usage etc.
visibility (STRING): To whom the event is visible.
