ONTAP EMS reference
ha.takeoverimplowmem events
ha.takeoverimplowmem EMS events occur when the partner node is down; however, due to this node being low on memory, it is currently impossible to perform a takeover.
ha.takeoverImpLowMem
Severity
ERROR
This message occurs when the partner node is down; however, due to this node being low on memory, it is currently impossible to perform a takeover.
Corrective Action
Contact NetApp technical support.
Syslog Message
Takeover of the partner node is impossible due to a low memory situation.
(None).
