ONTAP EMS reference
km.volume events
km.volume EMS events occur when ONTAP encounters issues associated with key manager recovery during volume mount operations.
km.volume.mount.fail
Severity
ALERT
This message occurs during the recovery of the key manager when a volume is placed online, but fails to mount. Volumes need to be mounted manually.
Corrective Action
The volume needs to be mounted manually with the provided junction using the "volume mount" command.
Syslog Message
Vserver "%s" failed to mount volume: "%s" to junction path: "%s" during key manager recovery.
vserver (STRING): Name of the Vserver that owns the volumes being placed online.
volume (STRING): Name of the the volume being placed online.
junction (STRING): Name of the junction path to mount.
km.volume.mount.mismatch
Severity
ALERT
This message occurs during recovery of the key manager when a junction path cannot identify the volume to mount. Pair the supplied junction with its volume and mount manually.
Corrective Action
The volumes are online but need to be mounted manually using the "volume mount" command.
Syslog Message
During health monitor recovery of the key manager on Vserver "%s", the junction path "%s" cannot be associated with the volume to mount.
vserver (STRING): Name of the Vserver that owns the volume that could not be mounted.
