ONTAP EMS reference
smc.cg events
smc.cg EMS events occur when a FlexGroup® snapshot rename fails and the revert to the original snapshot name also fails.
smc.cg.snap.ren.revert.fail
Severity
ERROR
This message occurs when a FlexGroup® snapshot rename fails and the revert to the original snapshot name also fails.
Corrective Action
Manually rename the snapshot by issuing the "snapshot rename" command.
Syslog Message
Unable to revert snapshot name from the new name, "%s" to oldname "%s" in volume "%s".
newsnapname (STRING): New snapshot name.
origsnapname (STRING): Original snapshot name.
dstpath (STRING): Path name of the destination volume to which the snapshot rename was issued.
error (INT): Error code of the failure.
