ONTAP EMS reference
snapvault.sys events
snapvault.sys EMS events occur when ONTAP encounters issues associated with SnapVault® system operations.
snapvault.sys.internal
Severity
ERROR
This message occurs when SnapVault® encounters an internal error.
Corrective Action
Turn off SnapVault and restart it.
Syslog Message
An internal error occurred in SnapVault®: %s.
reason (STRING): Reason for the internal error.
snapvault.sys.upgrade
Severity
ERROR
During initialization, SnapVault will attempt to update all the qtree metadata flags if necessary. This message is generated if there is insufficient memory to perform this operation.
Corrective Action
Convert the qtrees manually or contact NetApp technical support to help.
Syslog Message
Low on memory. Can't automatically convert snapvault qtrees right now, so backups will fail. Convert the qtrees manually or contact NetApp technical support to help.
(None).
snapvault.sys.vfilerOn
Severity
INFORMATIONAL
This message occurs when SnapVault® is enabled on a vfiler during shutdown, where it is expected to be disabled.
Corrective Action
None needed. This is for information only.
Syslog Message
(None).
vfiler (STRING): Name of the vfiler.
