ucm.disabled events
ucm.disabled EMS events occur when the Unified Target Adapter reads an invalid mode from flash memory.
ucm.disabled.slot
- Severity
ERROR
- Description
This message occurs when the Unified Target Adapter reads an invalid mode from flash memory. The valid supported modes are FC (0x1) or CNA (0x2). The adapter's flash memory has failed or has been corrupted. The adapter will be disabled.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Disabling adapter %s because invalid mode %d was read from nonvolatile memory.
- Parameters
adapter (STRING): Name of the affected adapter.
faultyMode (INT): Value of the mode read from flash memory.
