wafl.remote events
wafl.remote EMS events occur when WAFL cannot get enough storage space for remote caching to function properly.
wafl.remote.cannot.refill.fsps
- Severity
ERROR
- Description
This message occurs when WAFL cannot get enough storage space for remote caching to function properly. It can occur when a FlexGroup constituent volume is completely full, or when a thin constituent volume is mounted and the aggregate is full. This will cause some metadata operations to fail.
- Corrective Action
Free up constituent volume space by deleting files, moving files to a different constituent volume, or use the "vol modify -volume <volume-name> -size <new-size-value>" command to expand the size of the constituent volume. If you need assistance, contact NetApp technical support.
- Syslog Message
Cannot refill the RAL FSP reserves for constituent volume with DSID "%u" and name "%s".
- Parameters
constituent_volume_dsid (LONGINT): Data Set Identifier (DSID) of the constituent volume.
constituent_volume_name (STRING): Name of the constituent volume.
