ONTAP EMS reference
wafl.remote events
wafl.remote EMS events occur when WAFL cannot get enough storage space for remote caching to function properly.
wafl.remote.cannot.refill.fsps
Severity
ERROR
This message occurs when WAFL cannot get enough storage space for remote caching to function properly. It can occur when a FlexGroup constituent volume is completely full, or when a thin constituent volume is mounted and the aggregate is full. This will cause some metadata operations to fail.
Corrective Action
Free up constituent volume space by deleting files, moving files to a different constituent volume, or use the "vol modify -volume <volume-name> -size <new-size-value>" command to expand the size of the constituent volume. If you need assistance, contact NetApp technical support.
Syslog Message
Cannot refill the RAL FSP reserves for constituent volume with DSID "%u" and name "%s".
constituent_volume_dsid (LONGINT): Data Set Identifier (DSID) of the constituent volume.
constituent_volume_name (STRING): Name of the constituent volume.
