Reasons storage arrays are missing from command output
PDF of this doc site
Creating your file...
Your file is ready
A storage array that is not connected to the ONTAP system does not appear in the storage array config show
output. Problems with cabling, zoning, and host group configuration can prevent a connection between the two devices.
Resolving the issue
Check cabling, host group configuration, and zoning as follows:
Check that cables are connected.
Check that the WWPNs for the FC initiators on the ONTAP systems are in the host group.
Check that both the storage array and the FC initiator are in the same zone.
After the problem is fixed, run
in ONTAP to confirm that the issue was fixed.
