Configure the IP switches in a MetroCluster IP configuration
You must configure any IP switches that were replaced.
This task applies to MetroCluster IP configurations only.
This must be done on both switches. Verify after configuring the first switch that storage access on the surviving site is not impacted.
You must not proceed with the second switch if storage access on the surviving site is impacted. |
Refer to MetroCluster IP installation and configuration: : Differences among the ONTAP MetroCluster configurations for procedures for cabling and configuring a replacement switch.
You can use the procedures in the following sections:
Cabling the IP switches
Configuring the IP switches
If the ISLs were disabled at the surviving site, enable the ISLs and verify that the ISLs are online.
Enable the ISL interfaces on the first switch:
no shutdownThe following examples show the commands for a Broadcom IP switch or a Cisco IP switch.
Switch vendor
Commands
Broadcom
(IP_Switch_A_1)> enable (IP_switch_A_1)# configure (IP_switch_A_1)(Config)# interface 0/13-0/16 (IP_switch_A_1)(Interface 0/13-0/16 )# no shutdown (IP_switch_A_1)(Interface 0/13-0/16 )# exit (IP_switch_A_1)(Config)# exit
Cisco
IP_switch_A_1# conf t IP_switch_A_1(config)# int eth1/15-eth1/20 IP_switch_A_1(config)# no shutdown IP_switch_A_1(config)# copy running startup IP_switch_A_1(config)# show interface brief
Enable the ISL interfaces on the partner switch:
Switch vendor
Commands
Broadcom
(IP_Switch_A_2)> enable (IP_switch_A_2)# configure (IP_switch_A_2)(Config)# interface 0/13-0/16 (IP_switch_A_2)(Interface 0/13-0/16 )# no shutdown (IP_switch_A_2)(Interface 0/13-0/16 )# exit (IP_switch_A_2)(Config)# exit
Cisco
IP_switch_A_2# conf t IP_switch_A_2(config)# int eth1/15-eth1/20 IP_switch_A_2(config)# no shutdown IP_switch_A_2(config)# copy running startup IP_switch_A_2(config)# show interface brief
Verify that the interfaces are enabled:
show interface briefThe following example shows the output for a Cisco switch.
IP_switch_A_2(config)# show interface brief -------------------------------------------------------- Port VRF Status IP Address Speed MTU -------------------------------------------------------- mt0 -- up 10.10.99.10 100 1500 -------------------------------------------------------- Ethernet VLAN Type Mode Status Reason Speed Port Interface Ch # -------------------------------------------------------- . . . Eth1/15 10 eth access up none 40G(D) -- Eth1/16 10 eth access up none 40G(D) -- Eth1/17 10 eth access down none auto(D) -- Eth1/18 10 eth access down none auto(D) -- Eth1/19 10 eth access down none auto(D) -- Eth1/20 10 eth access down none auto(D) -- . . . IP_switch_A_2#
