Rename a cluster in a MetroCluster configuration
Renaming a cluster in a MetroCluster configuration involves making the changes, and then verifying on both the local and remote clusters that the change took effect correctly.
View the cluster names using the
metrocluster node showcommand:
cluster_1::*> metrocluster node show DR Configuration DR Group Cluster Node State Mirroring Mode ----- ------- ------------------ -------------- --------- -------------------- 1 cluster_1 node_A_1 configured enabled normal node_A_2 configured enabled normal cluster_2 node_B_1 configured enabled normal node_B_2 configured enabled normal 4 entries were displayed. -
Rename the cluster:
cluster identity modify -name new_nameIn the following example, the
cluster_1cluster is renamedcluster_A:cluster_1::*> cluster identity modify -name cluster_A
Verify on the local cluster that the renamed cluster is running normally:
metrocluster node showIn the following example, the newly renamed
cluster_Ais running normally:cluster_A::*> metrocluster node show DR Configuration DR Group Cluster Node State Mirroring Mode ----- ------- ------------------ -------------- --------- -------------------- 1 cluster_A node_A_1 configured enabled normal node_A_2 configured enabled normal cluster_2 node_B_1 configured enabled normal node_B_2 configured enabled normal 4 entries were displayed. -
Rename the remote cluster:
cluster peer modify-local-name -name cluster_2 -new-name cluster_BIn the following example,
cluster_2is renamedcluster_B:cluster_A::> cluster peer modify-local-name -name cluster_2 -new-name cluster_B
Verify on the remote cluster that the local cluster was renamed and is running normally:
cluster_Bis running normally:cluster_B::*> metrocluster node show DR Configuration DR Group Cluster Node State Mirroring Mode ----- ------- ------------------ -------------- --------- -------------------- 1 cluster_B node_B_1 configured enabled normal node_B_2 configured enabled normal cluster_A node_A_1 configured enabled normal node_A_2 configured enabled normal 4 entries were displayed. -
Repeat these steps for each cluster that you want to rename.
