Move the local cluster connections in a MetroCluster FC-to-IP transition
Move the MetroCluster FC configuration's cluster interfaces to the IP switches.
Step 1: Move the cluster connections on the MetroCluster FC nodes
Move the cluster connections on the MetroCluster FC nodes to the IP switches. The steps you follow depend on whether you're using existing IP switches or new IP switches.
You perform this task on both MetroCluster sites.
Which connections to move
The following task assumes a controller module is using two ports for the cluster connections. Some controller module models use four or more ports for the cluster connection. In this example, the ports are divided into two groups, alternating ports between the two groups.
The following table shows the example ports used in this task.
Number of cluster connections on the controller module |
Group A ports |
Group B ports |
Two |
e0a |
e0b |
Four |
e0a, e0c |
e0b, e0d |
Group A ports connect to local switch switch_x_1-IP.
Group B ports connect to local switch switch_x_2-IP.
The following table shows which switch ports the FC nodes connect to. For the Broadcom BES-53248 switch, the port usage depends on the model of the MetroCluster IP nodes.
Switch model |
MetroCluster IP node model |
Switch port(s) |
Connects to |
Cisco 3132Q-V |
Any |
5, 6 |
Local cluster interface on FC node |
Cisco 9336C-FX2 (12-port) |
Any |
3,4, or 11,12 Note: To use switch ports 11 and 12, you must select two speed modes. |
Cisco 3232C, or 9336C-FX2 (36-port) |
Any |
5, 6, or 13, 14 Note: To use switch ports 13 and 14, you must select two speed modes. |
Cisco 9336C-FX2 shared (36-port) |
Any |
Broadcom BES-53248 |
FAS500f/A250 |
1 - 6 |
FAS8200/A300 |
3, 4, 9, 10, 11, 12 |
FAS8300/A400/FAS8700 |
1 - 6 |
NVIDIA SN2100 |
Any |
5,6, or 11,12 Note: To use switch ports 11 and 12, you must select two speed modes. |
Move the local cluster connections when using new IP switches
If you are using new IP switches, you physically move the existing MetroCluster FC nodes' cluster connections to the new switches.
Move the MetroCluster FC node group A cluster connections to the new IP switches.
Use the ports described in Which connections to move.
Disconnect all the group A ports from the switch, or, if the MetroCluster FC configuration was a switchless cluster, disconnect them from the partner node.
Disconnect the group A ports from node_A_1-FC and node_A_2-FC.
Connect the group A ports of node_A_1-FC to the switch ports for the FC node on switch_A_1-IP
Connect the group A ports of node_A_2-FC to the switch ports for the FC node on switch_A_1-IP
Verify that all cluster ports are up:
network port show -ipspace Clustercluster_A::*> network port show -ipspace Cluster Node: node_A_1-FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: node_A_2-FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed. cluster_A::*> -
Verify that your inter-site Inter-Switch Links (ISLs) are up and the port-channels are operational:
show interface briefIn the following example, ISL ports “Eth1/15” to “Eth1/20” are configured as “Po10” for the remote site link and “Eth1/7” to “Eth1/8” are configured as “Po1” for the local cluster ISL. The state of “Eth1/15” to “Eth1/20”, “Eth1/7” to “Eth1/8”, “Po10”, and “Po1” should be 'up'.
IP_switch_A_1# show interface brief -------------------------------------------------------------- Port VRF Status IP Address Speed MTU -------------------------------------------------------------- mgmt0 -- up 100.10.200.20 1000 1500 -------------------------------------------------------------------------------- Ethernet VLAN Type Mode Status Reason Speed Port Interface Ch # -------------------------------------------------------------------------------- ... Eth1/7 1 eth trunk up none 100G(D) 1 Eth1/8 1 eth trunk up none 100G(D) 1 ... Eth1/15 1 eth trunk up none 100G(D) 10 Eth1/16 1 eth trunk up none 100G(D) 10 Eth1/17 1 eth trunk up none 100G(D) 10 Eth1/18 1 eth trunk up none 100G(D) 10 Eth1/19 1 eth trunk up none 100G(D) 10 Eth1/20 1 eth trunk up none 100G(D) 10 -------------------------------------------------------------------------------- Port-channel VLAN Type Mode Status Reason Speed Protocol Interface -------------------------------------------------------------------------------- Po1 1 eth trunk up none a-100G(D) lacp Po10 1 eth trunk up none a-100G(D) lacp Po11 1 eth trunk down No operational auto(D) lacp members IP_switch_A_1# -
Verify that all interfaces display true in the “Is Home” column:
network interface show -vserver clusterThis might take several minutes to complete.
cluster_A::*> network interface show -vserver cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ----- Cluster node_A_1_FC_clus1 up/up 169.254.209.69/16 node_A_1_FC e0a true node_A_1-FC_clus2 up/up 169.254.49.125/16 node_A_1-FC e0b true node_A_2-FC_clus1 up/up 169.254.47.194/16 node_A_2-FC e0a true node_A_2-FC_clus2 up/up 169.254.19.183/16 node_A_2-FC e0b true 4 entries were displayed. cluster_A::*> -
Perform the above steps on both nodes (node_A_1-FC and node_A_2-FC) to move the group B ports of the cluster interfaces.
Repeat the above steps on the partner cluster “cluster_B”.
Move the local cluster connections when reusing existing IP switches
If you are reusing existing IP switches, you update firmware, reconfigure the switches with the correct reference configuration files (RCFs) and move the connections to the correct ports one switch at a time.
This task is required only if the FC nodes are connected to existing IP switches and you are reusing the switches.
Disconnect the local cluster connections that connect to switch_A_1_IP
Disconnect the group A ports from the existing IP switch.
Disconnect the ISL ports on switch_A_1_IP.
You can see the Installation and Setup instructions for the platform to see the cluster port usage.
Reconfigure switch_A_1_IP using RCF files generated for your platform combination and transition.
Follow the steps in the procedure for your switch vendor from MetroCluster IP Installation and Configuration:
If required, download and install the new switch firmware.
You should use the latest firmware that the MetroCluster IP nodes support.
Prepare the IP switches for the application of the new RCF files.
Download and install the IP RCF file depending on your switch vendor.
Reconnect the group A ports to switch_A_1_IP.
network port show -ipspace clusterCluster-A::*> network port show -ipspace cluster Node: node_A_1_FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: node_A_2_FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed. Cluster-A::*> -
Verify that all interfaces are on their home port:
network interface show -vserver ClusterCluster-A::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ----- Cluster node_A_1_FC_clus1 up/up 169.254.209.69/16 node_A_1_FC e0a true node_A_1_FC_clus2 up/up 169.254.49.125/16 node_A_1_FC e0b true node_A_2_FC_clus1 up/up 169.254.47.194/16 node_A_2_FC e0a true node_A_2_FC_clus2 up/up 169.254.19.183/16 node_A_2_FC e0b true 4 entries were displayed. Cluster-A::*> -
Repeat all the previous steps on switch_A_2_IP.
Reconnect the local cluster ISL ports.
Repeat the above steps at site_B for switch B_1_IP and switch B_2_IP.
Connect the remote ISLs between the sites.
Step 2: Verify that the cluster connections are moved and the cluster is healthy
To ensure that there is proper connectivity and that the configuration is ready to proceed with the transition process, verify that the cluster connections are moved correctly, the cluster switches are recognized and the cluster is healthy.
Verify that all cluster ports are up and running:
network port show -ipspace ClusterCluster-A::*> network port show -ipspace Cluster Node: Node-A-1-FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: Node-A-2-FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed. Cluster-A::*> -
network interface show -vserver ClusterThis might take several minutes to complete.
The following example shows that all interfaces show true in the “Is Home” column.
Cluster-A::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ----- Cluster Node-A-1_FC_clus1 up/up 169.254.209.69/16 Node-A-1_FC e0a true Node-A-1-FC_clus2 up/up 169.254.49.125/16 Node-A-1-FC e0b true Node-A-2-FC_clus1 up/up 169.254.47.194/16 Node-A-2-FC e0a true Node-A-2-FC_clus2 up/up 169.254.19.183/16 Node-A-2-FC e0b true 4 entries were displayed. Cluster-A::*> -
Verify that both the local IP switches are discovered by the nodes:
network device-discovery show -protocol cdpCluster-A::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- Node-A-1-FC /cdp e0a Switch-A-3-IP 1/5/1 N3K-C3232C e0b Switch-A-4-IP 0/5/1 N3K-C3232C Node-A-2-FC /cdp e0a Switch-A-3-IP 1/6/1 N3K-C3232C e0b Switch-A-4-IP 0/6/1 N3K-C3232C 4 entries were displayed. Cluster-A::*> -
On the IP switch, verify that the MetroCluster IP nodes have been discovered by both local IP switches:
show cdp neighborsYou must perform this step on each switch.
This example shows how to verify the nodes are discovered on Switch-A-3-IP.
(Switch-A-3-IP)# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID Node-A-1-FC Eth1/5/1 133 H FAS8200 e0a Node-A-2-FC Eth1/6/1 133 H FAS8200 e0a Switch-A-4-IP(FDO220329A4) Eth1/7 175 R S I s N3K-C3232C Eth1/7 Switch-A-4-IP(FDO220329A4) Eth1/8 175 R S I s N3K-C3232C Eth1/8 Switch-B-3-IP(FDO220329B3) Eth1/20 173 R S I s N3K-C3232C Eth1/20 Switch-B-3-IP(FDO220329B3) Eth1/21 173 R S I s N3K-C3232C Eth1/21 Total entries displayed: 4 (Switch-A-3-IP)#This example shows how to verify that the nodes are discovered on Switch-A-4-IP.
(Switch-A-4-IP)# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID Node-A-1-FC Eth1/5/1 133 H FAS8200 e0b Node-A-2-FC Eth1/6/1 133 H FAS8200 e0b Switch-A-3-IP(FDO220329A3) Eth1/7 175 R S I s N3K-C3232C Eth1/7 Switch-A-3-IP(FDO220329A3) Eth1/8 175 R S I s N3K-C3232C Eth1/8 Switch-B-4-IP(FDO220329B4) Eth1/20 169 R S I s N3K-C3232C Eth1/20 Switch-B-4-IP(FDO220329B4) Eth1/21 169 R S I s N3K-C3232C Eth1/21 Total entries displayed: 4 (Switch-A-4-IP)#
