Complete the MetroCluster IP controller upgrade
After upgrading the controller modules, perform the necessary tasks to complete the controller upgrade.
Check the health of the MetroCluster configuration
After upgrading the controller modules you must verify the health of the MetroCluster configuration.
You can perform this task on any node in the MetroCluster configuration.
Verify the operation of the MetroCluster configuration:
Confirm the MetroCluster configuration and that the operational mode is normal:
metrocluster show -
Perform a MetroCluster check:
metrocluster check run -
Display the results of the MetroCluster check:
metrocluster check show
Verify the MetroCluster connectivity and status.
Check the MetroCluster IP connections:
set -privilege advancedstorage iscsi-initiator show -
Check that the nodes are operating:
metrocluster node show -
Check that the MetroCluster IP interfaces are up:
metrocluster configuration-settings interface show -
Check that local failover is enabled:
storage failover show
Upgrade the nodes on cluster_A
You must repeat the upgrade tasks to upgrade the nodes on cluster_A at site A.
Repeat the steps to upgrade the nodes on cluster_A, beginning with Prepare for the upgrade.
When you repeat the procedure, all example references to the clusters and nodes are reversed. For example, when the example is given to switchover from cluster_A, you will switchover from cluster_B.
Re-add the internal drives to the new controller
If you upgraded from a system that only has external drives to a system that has external and internal drives (disks and controllers in the same chassis), you can add or re-seat the disks that you removed or unseated from the internal slots of the new system. You can do this at any time after the upgrade is completed on both sites and the cluster is in a healthy state.
After you re-add or re-seat the drives, they can be used in ONTAP as required.
This task only applies to certain upgrade combinations. Refer to remove internal drives from the chassis on the new controller for more information. |
Restore Tiebreaker or Mediator monitoring
After completing the upgrade of the MetroCluster configuration, you can resume monitoring with the Tiebreaker or Mediator utility.
Restore monitoring if necessary, using the procedure for your configuration.
If you are using… Use this procedure Tiebreaker
Mediator
Third-party applications
Refer to the product documentation.
Send a custom AutoSupport message after maintenance
After completing the upgrade, you should send an AutoSupport message indicating the end of maintenance, so automatic case creation can resume.
To resume automatic support case generation, send an Autosupport message to indicate that the maintenance is complete.
Issue the following command:
system node autosupport invoke -node * -type all -message MAINT=end -
Repeat the command on the partner cluster.
Configure end-to-end encryption
If it is supported on your system, you can encrypt back-end traffic, such as NVlog and storage replication data, between the MetroCluster IP sites. Refer to Configure end-to-end encryption for more information.
