ONTAP MetroCluster
Restore HBA configuration and set HA state for MetroCluster IP controllers
Contributors netapp-aoife
Configure the HBA cards in the controller module and verify and set the HA state of the controller and chassis.
Restore the HBA configuration
Depending on the presence and configuration of HBA cards in the controller module, you need to configure them correctly for your site.
Steps
  1. In Maintenance mode, configure the settings for any HBAs in the system:
    1. Check the current settings of the ports: ucadmin show
    2. Update the port settings as needed.
    If you have this type of HBA and desired mode…​
    Use this command…​
    CNA FC
    ucadmin modify -m fc -t initiator <adapter-name>
    CNA Ethernet
    ucadmin modify -mode cna <adapter-name>
    FC target
    fcadmin config -t target <adapter-name>
    FC initiator
    fcadmin config -t initiator <adapter-name>
  2. Exit Maintenance mode:
    halt
    After you run the command, wait until the node stops at the LOADER prompt.
  3. Boot the node back into Maintenance mode to apply the configuration changes:
    boot_ontap maint
  4. Verify the changes:
    If you have this type of HBA…​
    Use this command…​
    CNA
    ucadmin show
    FC
    fcadmin show
Set the HA state on the new controllers and chassis
You must verify the HA state of the controllers and chassis, and, if necessary, update the state to match your system configuration.
Steps
  1. In Maintenance mode, display the HA state of the controller module and chassis:
    ha-config show
    The HA state for all components should be mccip.
  2. If the displayed system state of the controller or chassis isn't correct, set the HA state:
    ha-config modify controller mccip
    ha-config modify chassis mccip
  3. Verify and modify the Ethernet ports connected to NS224 shelves or storage switches.
    1. Verify the Ethernet ports connected to NS224 shelves or storage switches:
      storage port show
    2. Set all Ethernet ports connected to Ethernet shelves or storage switches, including shared switches for storage and cluster, to storage mode:
      storage port modify -p <port> -m storage
      Example:
      *> storage port modify -p e5b -m storage
      Changing NVMe-oF port e5b to storage mode
      Note This must be set on all affected ports for a successful upgrade.
      Disks from the shelves attached to the Ethernet ports are reported in the sysconfig -v output.
      Refer to the Hardware Universe for information on the storage ports for the system you are upgrading to.
    3. Verify that storage mode is set and confirm that the ports are in the online state:
      storage port show
  4. Halt the node: halt
    The node should stop at the LOADER> prompt.
  5. On each node, check the system date, time, and time zone: show date
  6. If necessary, set the date in UTC or GMT: set date <mm/dd/yyyy>
  7. Check the time by using the following command at the boot environment prompt: show time
  8. If necessary, set the time in UTC or GMT: set time <hh:mm:ss>
  9. Save the settings: saveenv
  10. Gather environment variables: printenv
Remove internal drives from the chassis on the new controller
When you upgrade from a system that only has external drives to a system that has external and internal drives (disks and controllers in the same chassis), you need to remove or unseat all internal drives from the new system until you have completed the upgrade.
Caution This task is mandatory for a successful controller upgrade on affected systems.
To determine if your upgrade combination is affected, refer to the table in Supported controller upgrades. If your upgrade combination is marked with Note 3, you must remove or unseat the internal drives from the new system.
After you complete this task, no internal drives should be accessible. You'll add the drives to the new controller later in the procedure.
