Move Linux iSCSI hosts from MetroCluster FC to MetroCluster IP nodes
After you transition your MetroCluster nodes from FC to IP, you might need to move your iSCSI host connections to the new nodes.
IPv4 interfaces are created when you set up the new iSCSI connections.
The host commands and examples are specific to Linux operating systems.
The MetroCluster FC nodes are called old nodes and the MetroCluster IP nodes are called new nodes.
Step 1: Set up new iSCSI connections
To move the iSCSI connections, you set up new iSCSI connections to the new nodes.
Create iSCSI interfaces on the new nodes and check ping connectivity from the iSCSI hosts to the new interfaces on the new nodes.
All iSCSI interfaces from the SVM should be reachable by the iSCSI host.
On the iSCSI host, identify the existing iSCSI connections from the host to the old node:
iscsiadm -m session[root@scspr1789621001 ~]# iscsiadm -m session tcp: [1] 10.230.68.236:3260,1156 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 (non-flash) tcp: [2] 10.230.68.237:3260,1158 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 (non-flash)
On the new node, verify the connections from the new node:
iscsi session show -vserver <svm-name>node_A_1-new::*> iscsi session show -vserver vsa_1 Tpgroup Initiator Initiator Vserver Name TSIH Name ISID Alias --------- ------- ---- ------------------------ --------- --------------------- vsa_1 iscsi_lf__n1_p1_ 4 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:01 scspr1789621001.gdl.englab.netapp.com vsa_1 iscsi_lf__n2_p1_ 4 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:02 scspr1789621001.gdl.englab.netapp.com 2 entries were displayed.
On the new node, list the iSCSI interfaces in ONTAP for the SVM that contains the interfaces:
iscsi interface show -vserver <svm-name>sti8200mcchtp001htp_siteA::*> iscsi interface show -vserver vsa_1 Logical Status Curr Curr Vserver Interface TPGT Admin/Oper IP Address Node Port Enabled ------- ---------- ---- ---------- --------------- ----------- ---- ------- vsa_1 iscsi_lf__n1_p1_ 1156 up/up 10.230.68.236 sti8200mcc-htp-001 e0g true vsa_1 iscsi_lf__n1_p2_ 1157 up/up fd20:8b1e:b255:805e::78c9 sti8200mcc-htp-001 e0h true vsa_1 iscsi_lf__n2_p1_ 1158 up/up 10.230.68.237 sti8200mcc-htp-002 e0g true vsa_1 iscsi_lf__n2_p2_ 1159 up/up fd20:8b1e:b255:805e::78ca sti8200mcc-htp-002 e0h true vsa_1 iscsi_lf__n3_p1_ 1183 up/up 10.226.43.134 sti8200mccip-htp-005 e0c true vsa_1 iscsi_lf__n4_p1_ 1188 up/up 10.226.43.142 sti8200mccip-htp-006 e0c true 6 entries were displayed.
On the iSCSI host, run discovery on any one of the iSCSI IP addresses on the SVM to discover the new targets:
iscsiadm -m discovery -t sendtargets -p iscsi-ip-addressDiscovery can be run on any IP address of the SVM, including non-iSCSI interfaces.
[root@scspr1789621001 ~]# iscsiadm -m discovery -t sendtargets -p 10.230.68.236:3260 10.230.68.236:3260,1156 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 10.226.43.142:3260,1188 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 10.226.43.134:3260,1183 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 10.230.68.237:3260,1158 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6
On the iSCSI host, login to all the discovered addresses:
iscsiadm -m node -L all -T node-address -p portal-address -l[root@scspr1789621001 ~]# iscsiadm -m node -L all -T iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 -p 10.230.68.236:3260 -l Logging in to [iface: default, target: iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6, portal: 10.226.43.142,3260] (multiple) Logging in to [iface: default, target: iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6, portal: 10.226.43.134,3260] (multiple) Login to [iface: default, target: iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6, portal: 10.226.43.142,3260] successful. Login to [iface: default, target: iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6, portal: 10.226.43.134,3260] successful.
On the iSCSI host, verify the login and connections:
iscsiadm -m session[root@scspr1789621001 ~]# iscsiadm -m session tcp: [1] 10.230.68.236:3260,1156 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 (non-flash) tcp: [2] 10.230.68.237:3260,1158 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 (non-flash) tcp: [3] 10.226.43.142:3260,1188 iqn.1992-08.com.netapp:sn.58d7f6df2cc611eaa9c500a098a71638:vs.6 (non-flash)
On the new node, verify the login and connection with the host:
iscsi initiator show -vserver <svm-name>sti8200mcchtp001htp_siteA::*> iscsi initiator show -vserver vsa_1 Tpgroup Initiator Vserver Name TSIH Name ISID Igroup Name ------- -------- ---- --------------------- ----------------- ----------------- vsa_1 iscsi_lf__n1_p1_ 4 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:01 igroup_linux vsa_1 iscsi_lf__n2_p1_ 4 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:02 igroup_linux vsa_1 iscsi_lf__n3_p1_ 1 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:04 igroup_linux vsa_1 iscsi_lf__n4_p1_ 1 iqn.2020-01.com.netapp.englab.gdl:scspr1789621001 00:02:3d:00:00:03 igroup_linux 4 entries were displayed.
At the end of this task, the host can see all iSCSI interfaces (on the old and new nodes) and is logged in to all those interfaces.
LUNs and volumes are still physically hosted on the old nodes. Because LUNs are reported only on the old node interfaces, the host shows only paths over the old nodes. To see this, run the sanlun lun show -p and multipath -ll -d commands on the host and examine the command outputs.
[root@scspr1789621001 ~]# sanlun lun show -p ONTAP Path: vsa_1:/vol/vsa_1_vol6/lun_linux_12 LUN: 4 LUN Size: 2g Product: cDOT Host Device: 3600a098038304646513f4f674e52774b Multipath Policy: service-time 0 Multipath Provider: Native --------- ---------- ------- ------------ ------------------- host vserver path path /dev/ host vserver state type node adapter LIF --------- ---------- ------- ------------ ------------------- up primary sdk host3 iscsi_lf__n2_p1_ up secondary sdh host2 iscsi_lf__n1_p1_ [root@scspr1789621001 ~]# multipath -ll -d 3600a098038304646513f4f674e52774b dm-5 NETAPP ,LUN C-Mode size=2.0G features='4 queue_if_no_path pg_init_retries 50 retain_attached_hw_handle' hwhandler='1 alua' wp=rw |-+- policy='service-time 0' prio=50 status=active | `- 3:0:0:4 sdk 8:160 active ready running `-+- policy='service-time 0' prio=10 status=enabled `- 2:0:0:4 sdh 8:112 active ready running
Step 2: Add the new nodes as reporting nodes
After setting up the connections to the new nodes, you add the new nodes as the reporting nodes.
On the new node, list reporting nodes for LUNs on the SVM:
lun mapping show -vserver <svm-name> -fields reporting-nodes -ostype linuxThe following reporting nodes are local nodes as LUNs are physically on old nodes node_A_1-old and node_A_2-old.
node_A_1-new::*> lun mapping show -vserver vsa_1 -fields reporting-nodes -ostype linux vserver path igroup reporting-nodes ------- ---------------------------- ------------ --------------------------- vsa_1 /vol/vsa_1_vol1/lun_linux_2 igroup_linux node_A_1-old,node_A_2-old . . . vsa_1 /vol/vsa_1_vol9/lun_linux_19 igroup_linux node_A_1-old,node_A_2-old 12 entries were displayed.
On the new node, add reporting nodes:
lun mapping add-reporting-nodes -vserver <svm-name> -path /vol/vsa_1_vol*/lun_linux_* -nodes node1,node2 -igroup <igroup_name>node_A_1-new::*> lun mapping add-reporting-nodes -vserver vsa_1 -path /vol/vsa_1_vol*/lun_linux_* -nodes node_A_1-new,node_A_2-new -igroup igroup_linux 12 entries were acted on.
On the new node, verify that the newly added nodes are present:
lun mapping show -vserver <svm-name> -fields reporting-nodes -ostype linux vserver path igroup reporting-nodesnode_A_1-new::*> lun mapping show -vserver vsa_1 -fields reporting-nodes -ostype linux vserver path igroup reporting-nodes ------- --------------------------- ------------ ------------------------------------------------------------------------------- vsa_1 /vol/vsa_1_vol1/lun_linux_2 igroup_linux node_A_1-old,node_A_2-old,node_A_1-new,node_A_2-new vsa_1 /vol/vsa_1_vol1/lun_linux_3 igroup_linux node_A_1-old,node_A_2-old,node_A_1-new,node_A_2-new . . . 12 entries were displayed.
The
sg3-utilspackage must be installed on the Linux host. This prevents arescan-scsi-bus.sh utility not founderror when you rescan the Linux host for the newly mapped LUNs using therescan-scsi-buscommand.On the host, verify that the
sg3-utilspackage is installed:-
For a Debian based distribution:
dpkg -l | grep sg3-utils -
For a Red Hat based distribution:
rpm -qa | grep sg3-utils
If required, install the
sg3-utilspackage on the Linux host:sudo apt-get install sg3-utils -
On the host, rescan the SCSI bus on the host and discover the newly added paths:
/usr/bin/rescan-scsi-bus.sh -a[root@stemgr]# /usr/bin/rescan-scsi-bus.sh -a Scanning SCSI subsystem for new devices Scanning host 0 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs Scanning host 1 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs Scanning host 2 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs Scanning for device 2 0 0 0 ... . . . OLD: Host: scsi5 Channel: 00 Id: 00 Lun: 09 Vendor: NETAPP Model: LUN C-Mode Rev: 9800 Type: Direct-Access ANSI SCSI revision: 05 0 new or changed device(s) found. 0 remapped or resized device(s) found. 0 device(s) removed.
On the iSCSI host, list the newly added paths:
sanlun lun show -pFour paths are shown for each LUN.
[root@stemgr]# sanlun lun show -p ONTAP Path: vsa_1:/vol/vsa_1_vol6/lun_linux_12 LUN: 4 LUN Size: 2g Product: cDOT Host Device: 3600a098038304646513f4f674e52774b Multipath Policy: service-time 0 Multipath Provider: Native ------- ---------- ------- ----------- --------------------- host vserver path path /dev/ host vserver state type node adapter LIF ------ ---------- ------- ----------- --------------------- up primary sdk host3 iscsi_lf__n2_p1_ up secondary sdh host2 iscsi_lf__n1_p1_ up secondary sdag host4 iscsi_lf__n4_p1_ up secondary sdah host5 iscsi_lf__n3_p1_
On the new node, move the volume/volumes containing LUNs from the old nodes to the new nodes.
node_A_1-new::*> vol move start -vserver vsa_1 -volume vsa_1_vol1 -destination-aggregate sti8200mccip_htp_005_aggr1 [Job 1877] Job is queued: Move "vsa_1_vol1" in Vserver "vsa_1" to aggregate "sti8200mccip_htp_005_aggr1". Use the "volume move show -vserver vsa_1 -volume vsa_1_vol1" command to view the status of this operation. node_A_1-new::*> vol move show Vserver Volume State Move Phase Percent-Complete Time-To-Complete -------- ---------- -------- ---------- ---------------- ---------------- ---------------- vsa_1 vsa_1_vol1 healthy initializing - -
When the volume move to the new nodes is complete, verify that the volume is online:
volume show -state -
The iSCSI interfaces on the new nodes where the LUN now resides are updated as primary paths. If the primary path is not updated after the volume move, run
/usr/bin/rescan-scsi-bus.sh -aandmultipath -v3on the host or simply wait for multipath rescanning to take place.In the following example, the primary path is a LIF on the new node.
[root@stemgr]# sanlun lun show -p ONTAP Path: vsa_1:/vol/vsa_1_vol6/lun_linux_12 LUN: 4 LUN Size: 2g Product: cDOT Host Device: 3600a098038304646513f4f674e52774b Multipath Policy: service-time 0 Multipath Provider: Native --------- ---------- ------- ------------ ----------------------- host vserver path path /dev/ host vserver state type node adapter LIF --------- ---------- ------- ------------ ------------------------ up primary sdag host4 iscsi_lf__n4_p1_ up secondary sdk host3 iscsi_lf__n2_p1_ up secondary sdh host2 iscsi_lf__n1_p1_ up secondary sdah host5 iscsi_lf__n3_p1_
Step 3: Remove reporting nodes and rescan paths
You must remove the reporting nodes and rescan the paths.
On the new node, remove remote reporting nodes (the new nodes) for the Linux LUNs:
lun mapping remove-reporting-nodes -vserver <svm-name> -path * -igroup <igroup_name> -remote-nodes trueIn this case, the remote nodes are old nodes.
node_A_1-new::*> lun mapping remove-reporting-nodes -vserver vsa_1 -path * -igroup igroup_linux -remote-nodes true 12 entries were acted on.
On the new node, check reporting nodes for the LUNs:
lun mapping show -vserver <svm-name> -fields reporting-nodes -ostype linuxnode_A_1-new::*> lun mapping show -vserver vsa_1 -fields reporting-nodes -ostype linux vserver path igroup reporting-nodes ------- --------------------------- ------------ ------------------------- vsa_1 /vol/vsa_1_vol1/lun_linux_2 igroup_linux node_A_1-new,node_A_2-new vsa_1 /vol/vsa_1_vol1/lun_linux_3 igroup_linux node_A_1-new,node_A_2-new vsa_1 /vol/vsa_1_vol2/lun_linux_4 group_linux node_A_1-new,node_A_2-new . . . 12 entries were displayed.
The
On the iSCSI host, rescan the SCSI bus:
/usr/bin/rescan-scsi-bus.sh -rThe paths that are removed are the paths from the old nodes.
[root@scspr1789621001 ~]# /usr/bin/rescan-scsi-bus.sh -r Syncing file systems Scanning SCSI subsystem for new devices and remove devices that have disappeared Scanning host 0 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs Scanning host 1 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs Scanning host 2 for SCSI target IDs 0 1 2 3 4 5 6 7, all LUNs sg0 changed: LU not available (PQual 1) REM: Host: scsi2 Channel: 00 Id: 00 Lun: 00 DEL: Vendor: NETAPP Model: LUN C-Mode Rev: 9800 Type: Direct-Access ANSI SCSI revision: 05 sg2 changed: LU not available (PQual 1) . . . OLD: Host: scsi5 Channel: 00 Id: 00 Lun: 09 Vendor: NETAPP Model: LUN C-Mode Rev: 9800 Type: Direct-Access ANSI SCSI revision: 05 0 new or changed device(s) found. 0 remapped or resized device(s) found. 24 device(s) removed. [2:0:0:0] [2:0:0:1] . . .
On the iSCSI host, verify that only paths from the new nodes are visible:
sanlun lun show -pmultipath -ll -d
