Generate and apply RCFs to the new MetroCluster IP switches
If you are using new IP switches for the MetroCluster IP configuration, you must configure the switches with a custom RCF file.
This task is required if you are using new switches.
If you are performing an four-node FC to eight-node IP transition, you can apply the four-node FC to eight-node IP RCF before you add the second DR group. You do not have to apply the four-node FC to four-node IP RCF first. |
If you are using existing switches, proceed to Moving the local cluster connections.
Install and rack the new IP switches.
Prepare the IP switches for the application of the new RCF files.
Follow the steps in the section for your switch vendor:
Update the firmware on the switch to a supported version, if necessary.
Use the RCF generator tool to create the RCF file depending on your switch vendor and the platform models, and then update the switches with the file.
