Disable encryption on Brocade switches in a MetroCluster FC configuration
You might need to disable encryption on Brocade FC switches.
Send an AutoSupport message from both sites indicating the beginning of maintenance.
cluster_A::> autosupport invoke -node * -type all -message MAINT=4h
cluster_B::> autosupport invoke -node * -type all -message MAINT=4h
Verify the operation of the MetroCluster configuration from Cluster A.
Confirm the MetroCluster configuration and that the operational mode is normal:
metrocluster showcluster_A::> metrocluster show
Perform a MetroCluster check:
metrocluster check runcluster_A::> metrocluster check run -
Display the results of the MetroCluster check:
metrocluster check showcluster_A::> metrocluster check show
Check the status of both switches:
fabric showswitch_A_1:admin> fabric show
switch_B_1:admin> fabric show
Disable both switches:
switchdisableswitch_A_1:admin> switchdisable
switch_B_1:admin> switchdisable
Check the available paths for the nodes on each cluster:
sysconfigcluster_A::> system node run -node node-name -command sysconfig -a
cluster_B::> system node run -node node-name -command sysconfig -a
As the switch fabric is now disabled, the System Storage Configuration should be Single-Path HA.
Check the aggregate status for both clusters.
cluster_A::> aggr status
cluster_B::> aggr status
System output should show the aggregates are mirrored and normal for both clusters:
mirrored,normal
Repeat the following substeps from the admin prompt on both switches.
Show which ports are encrypted:
portenccompshowswitch_A_1:admin> portenccompshow
Disable encryption on the encrypted ports:
portcfgencrypt – disable port-numberswitch_A_1:admin> portcfgencrypt --disable 40 switch_A_1:admin> portcfgencrypt --disable 41 switch_A_1:admin> portcfgencrypt --disable 42 switch_A_1:admin> portcfgencrypt --disable 43
Set the authentication type to all:
authUtil --set -a allswitch_A_1:admin> authUtil --set -a all
Set the authentication policy on the switch. to off:
authutil --policy -sw offswitch_A_1:admin> authutil --policy -sw off
Set the authentication Diffie-Hellman group to * :
authutil --set -g *switch_A_1:admin> authUtil --set -g *
Delete the secret key database:
secAuthSecret --remove -allswitch_A_1:admin> secAuthSecret --remove -all
Confirm that encryption is disabled on the ports:
Enable the switch:
switchenableswitch_A_1:admin> switchenable
Confirm the status of the ISLs:
islshowswitch_A_1:admin> islshow
sysconfigcluster_A::> system node run -node * -command sysconfig -a
cluster_B::> system node run -node * -command sysconfig -a
The system output should indicate that System Storage Configuration has changed back to Quad-Path HA.
The system should show that the aggregates are mirrored and normal for both clusters as shown in the following system output:
mirrored,normal
Send an AutoSupport message from both sites indicating the end of maintenance.
cluster_A::> autosupport invoke -node node-name -type all -message MAINT=END
cluster_B::> autosupport invoke -node node-name -type all -message MAINT=END
